Hello, i have done some searching and already suspect my
cam follower pin is bad, but wkndering if something else is at
issue too and would like to have all fhe parts in hand before i rip
it apart.
Problem started when using my back blade to plow snow...all
of a sudden the lift stopped lowering. Playing with the lever did
nothing and through some fluke i got it to lower once more.
one more pass and i went to lift the blade. It lifted slow and only
came up halfway. Would not go back down at all. Stayed up
over night for several days. Pulled the side cover and the lift
control arm appears to go up and dow. But not back and forth.
If i manually push the lever back it lowers. Then if you move
the lever to the full up position, it raises halfway unledd i lightly
pry the internal lever forward. Do that and it raises fully and will
also lower on its own with the touch control. If, on the way down
you move the lever to raise, or stop it lowering, it will stop then
not lower the rest of the way until i manually push the internal
lever backward.
Is this all follower pin? Or do I have two issues at play?
Oil looked ok when i drained it and I changed it last summer.
Tractor stays in the barn when not in use.
it apart.
lever backward.
