Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 8N Parts Online
Re: 8N 12 volt wiring problems
Bruce (VA)
01-02-2014 13:58:07
" Also, do I even need the voltage reducing resistor?"
Maybe.
Does the tractor have a front or side distributor?
What does the resistor look like?
Got a model/make of the alternator?
wasilla1
01-02-2014 14:48:27
 Re: 8N 12 volt wiring problems in reply to Bruce (VA), 01-02-2014 13:58:07
So, should I wire this as a single wire alternator??
wasilla1
01-02-2014 14:34:41
It is a front mount distributor.
It is a Delco-Remy alternator. I couldn't find any numbers on it, but post at rear says BAT.
I'm not positive of year of tractor...either a 1947 or 1948. Serial # is hard to read, real faint stamping, but it looks like 8NF1129????
The pic is what the new resistor I put on looks like. I will also try to post a pic of what I assume was a resistor that I took off. It would get cherry red hot and tractor would die. I would wait about 10 minutes for resistor to cool off and tractor would run for a while until it got cherry red hot again and die.
Bruce (VA)
01-02-2014 14:50:02
 Re: 8N 12 volt wiring problems in reply to wasilla1, 01-02-2014 14:34:41
See tip # 30 at the link; get rid of that resistor. Get the OEM ballast resistor (as in the picture) and a 12 volt coil.
Re the rest of the wiring, Google "wiring diagrams JMOR" and pick the one that fits your alternator.
Post back w/ results or more questions.
wasilla1
01-02-2014 14:58:36
 Re: 8N 12 volt wiring problems in reply to Bruce (VA), 01-02-2014 14:50:02
I put that one on. New block and resistor. It's in the top right center of my drawing on the original post. Internet research led me to believe I needed an additional one which is the voltage reducing resistor on the top left of my drawing.
Thanks,
Bill
carlntexas
01-02-2014 16:17:48
 Re: 8N 12 volt wiring problems in reply to wasilla1, 01-02-2014 14:58:36
I'm far from an expert on this,but I did rewire my 8N. It looks to be wired right from your drawing. Try shorting the wire to starter button to a good ground if it starts your button is bad. If this doesn't work you could have the wrong solenoid.
Looks like Jcinky answered better than me while I was typing.
This post was edited by carlntexas at 16:24:16 01/02/14.
wasilla1
01-02-2014 18:04:45
 Re: 8N 12 volt wiring problems in reply to carlntexas, 01-02-2014 16:17:48
Thanks. I'll try that tomorrow.
arnold z
01-02-2014 14:19:10
A lot of assuming on my part :) Better question is it for sure a 8N? I've bought a few Ns that had some wierd combos of resistors and coils that worked, and some that should have that didn't. The coils are pretty inconsistent nowdays.
Copyright © 1997-2015 Yesterday's Tractor Co.
