Premise: ANY lube is better than NO lube.
I've never been a fan of corn head grease for steering boxes of vintage Fords, prefering proper resealing and/or rebuilding and refilling with 90/140 or (preferably) CNH pourable high EP oil.
That said, I tried the cornhead shortcut about 5 years ago when I bought a very low hour 52 8N exhibiting steering box left turn lock up upon pre-purchase inspection.
After getting the 52 home, I pumped the dry steering gear box full of 90/140 using a marine lower unit pump and it immediately freed-up. Unfortunately, the OEM leather seals were long since dried out and worn out and would not hold the 90/140 in the gearbox.
Since the tractor was intended for light "quad" (carry all) duty and scheduled for proper restoration in the futhre, I decided to wait until the 90/140 stopped dripping from the sector shaft seals before commencing a corn head "experiment."
Once the 90/140 nearly stopped dripping from the sector shaft seals, I removed the (52 only) steering column air bleed screw and pumped the steering gear box full of JD corn head grease until it was forced out of the air bleed screw hole.
At the time, I thought that the corn head grease was far too thick for a steering gear box but, perhaps, the remainder of the 90/140 might flow into the voids to properly lubricate areas where the corn head grease was displaced.
Fast forward about three years.
About 3 or 4 weeks ago the 52 steering box started showing signs of inadequate lubrication when I used the tractor during cold weather. (I have used the tractor much more this winter than in the past several winters, and this winter has been colder than the past 2 or 3.)
After making a mental note, but before returning to the shop, the steering box exhibited the classic "no left turn" symptom of inadequate lubrication. I was able to force the tractor back into the barn by continually circling to the right and ultimately using the turning brakes to slide the front wheels into the stall.
I removed the 5' cutter from the 51, the carry all from the 52, and swapped the carry all to the 51 in order to be able to continue to do "quad" work.
Today, I was finally able to take a closer look at the 52.
Initially, I lifted the front end of the 52 and attempted to free up the steering by repetitive back and forth movement of the front spindles using both the steering wheels and the front wheels. No go.
It is January and my CNH pourable high EP oil is cold and not easily pumped using a marine lower unit pump so I decided to force more corn head grease into the gearbox using my grease gun that still had about 1/2 tube of corn head grease from the initial filling about 3 years ago.
Again, I removed the air bleed plug, and started pumping corn head grease into the gear box, turning the steering wheel to the right and back to the left lock-up after every 10 strokes or so. The front tires were elevated above ground.
After several attempts to free the gear box, I was resigned to remove and overhaul the (1100 Hr) gear box when the floating oil from the corn head grease and/or remaining 90/140 began to flow from the air bleed hole. Upon seeing this, I replaced the air bleed screw, removed the zerk bolt adapter, replaced the proper bolt and put away my tools and supplies.
Before lowering the front end, I once again cycled the steering right to left and all was free.
Bottom line: Corn head grease is much too thick for steering gear boxes and will not reflow into voids created by motion displacement when ambient temperature is low.
Yes, ANY lube is better than NO lube and you will likely get away with corn head grease in your steering gear box if you use your tractor only (mostly) in warm ambient when it will reflow or if your gear box is badly worn (not 1100 hrs) and not prone to lock-up.
Recommendation: Do not use corn head grease in steering boxes of vintage Ford tractors. Rather, use CNH pourable, high EP oil. This oil is MUCH thicker than 90W (though much less thick than corn head grease). It can be pumped into the gear boxes of vintage Ford tractors using a marine lower unit pump. Caveat: Pick a 90+ degree day. Do not try to do this in the winter.
Dean
Dean
