Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: OT 2000 Ranger
ASEguy
12-07-2013 05:04:06
I would not assume you don't have a vacuum leak with those codes. You may also have two issues. If the IAC motor is stuck open it will cause an inability to idle. A diagnostic tool would read IAC steps and from that you could determine whether it is sticking. You can also remove and clean the IAC motor pintle and seat for carbon build-up. At that time, since the engine would be cold, make sure the pintle is very close to it's seat. If it seems like it's stuck far from it's seat clean it or replace it but it has to move. You need to rule out issues brought up by Hobo, Matt and 4play as well. I would like to know if this driveability issue happens with every start of the truck or is intermittent. You said EGR is not stuck open, but EGR may need to be verified. If all checks well and is clean get it smoke tested. Hope this helps. Gerard
Copyright © 1997-2015 Yesterday's Tractor Co.
