Yesterday's Tractor Co. Tractor Parts for All Brands
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
bubbreing at WOT
steve 43
12-06-2013 13:05:53
67.209.72.118
I thought I had this prob licked when I noticed no gasket under my main needle...I could turn all the way in with no effect. After I put gasket in it kills at about 1/2 turn but no matter where I put it I cant get her to run smooth at WOT. She idles fine. Also thought I had the prob licked when I noticed loose park plug wires at the dist but that wasn't it either. Did all the spark and fuel checks....2n 6 volt points. Guess I'll check points...not many hours on them.
[Reply]   [No Email]
rustyfarmall
12-07-2013 07:28:00
208.126.186.41
 Re: bubbreing at WOT in reply to steve 43, 12-06-2013 13:05:53
I'd put 4 brand new spark plugs in it before I did anything else. Then I would be absolutely certain the ignition timing is dead on, and not advanced too much.
[Reply]  [No Email]
L.B,
12-06-2013 21:11:04
64.187.67.48
Front mount firing order 1243 if you cross 3&4 it will start and idle ok but will miss as you throttle up. If you choke it a bit at wot will it run better? If so mixture. Points if their china get them out buy Blue Sreaks they will last years.
[Reply]  [No Email]
old
12-06-2013 13:33:55
209.86.226.19
I would check spark at all 4 plug wires. Blue/white and jump a 1/4 inch gap or more. Next when was the last time you dumped the water and mud out of the air filter?? From there does choking it help or hurt?? Of it helps good chance the main jet is clogged up some if it hurts then maybe set to rich.
[Reply]  [No Email]
soundguy
12-06-2013 13:23:26
207.30.46.70
always verify spark first. .. do check timing and the advance mechanism too... THEN if all that checks out.. move to fuel..
[Reply]  [No Email]
R Geiger
12-06-2013 13:14:05
50.39.139.147
 Re: bubbreing at WOT in reply to El Toro, 12-06-2013 13:05:53
If you did not have the gasket, then what else in the carb is wrong? I would go completely thru carb or send it to someone who can! If it will not run smooth at wot something is wrong in carb. If it was the points it wold not run at an idle either. You might want to check the mechanical advance in the dist tho!
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
