Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 8N Parts Online
Re: Help with 8N with Mag
R Geiger
12-05-2013 18:03:26
Mine starts with the normal starter push button, so it is the same as my other side mount 8n. If you were using a hand crank like the war time model, then you better have it out of gear. When I first got mine running, I would kill it with the ground on the side of the mag. Then I ran the wire to the switch and then to ground. Then I learned to just turn the fuel off to shut her down. I used the wire in the harness that was meant to go to the dist to run to the switch.
