Anonymous-0
I have had my alternator in shop 2 times put on tractor will not work. need diagram of 8 n conversion .front dist. has 2 wire with jumper on end of alternator hooked to cold side of switch. hope you can figure this out thanks gene
gm 10si 3 wire alt is pretty easy.
charge stud to batter. ( or starter realy hot.. or thru ammeter.. make it fit your needs...
#2 spade jumped to charge stud.
#1 spade run thru a 194 trailer marker lamp element to switched side of key.
that's it..
This worked for me..
