TractorLinks.com
Show Parts for Model:
Re: round coil conversion question for Bob
NOXJohn
12-05-2013 09:33:22
I looked again at the kit this site sells and then looked at my tractor. You are correct. There is a plate that goes over the top of the distributor and cap. It is held in place by the screw shown in the kit and the coil wire adapter. If you plan to buy the kit call first and ask about the plate. I think a plate came with the kit I purchased. The cap is drilled and threaded to accept the coil wire adapter. I was wrong in my previous post. This will only work with EI. The screw goes in the hole where the condenser hold down screw is on a points system. A condenser would stick up to high for the plate to fit flat.
JMOR
12-05-2013 09:45:45
 Re: round coil conversion question for Bob in reply to NOXJohn, 12-05-2013 09:33:22
Quoting Removed, click Modern View to seeSame solution that Bob used for condenser in his roll-your-own conversion would allow the Pertronix block-off plate to work with points...........just mount condenser outside of distributor as on coil mounting bracket.
TheOldHokie
12-05-2013 09:39:34
I've been thinking about doing one of those for a while - it's actually quite easy ...
TOH
