TractorLinks.com
Show Parts for Model:
Re: round coil conversion question for Bob
NOXJohn
12-04-2013 12:33:43
You can make your own modified distributor cap and coil wire terminal or if you want to buy one already made up. Check out "Tractor Parts" on the left of this page. It is expensive but look at Distributor Cap Termination Kit 124XTTERM $17.62 and Pertronix Distributor Cap 124XTCP $27.95. Once you see a set of these you will see how easy it would be to make your own. My first conversion I used a modified gutted square can distributor. I found the front tab that contacts the distributor cap started to erode after one year with a 12 volt EI and a hot shot coil. The manufactured parts indicated above show no signs of wear after several years.
kylemorley
12-05-2013 08:21:28
 Re: round coil conversion question for Bob in reply to NOXJohn, 12-04-2013 12:33:43
Not sure I understand what that terminal kit does. Seems you would still need either a gutted square coil, or an adaptor plate to replace it.
NOXJohn
12-05-2013 09:33:22
 Re: round coil conversion question for Bob in reply to kylemorley, 12-05-2013 08:21:28
I looked again at the kit this site sells and then looked at my tractor. You are correct. There is a plate that goes over the top of the distributor and cap. It is held in place by the screw shown in the kit and the coil wire adapter. If you plan to buy the kit call first and ask about the plate. I think a plate came with the kit I purchased. The cap is drilled and threaded to accept the coil wire adapter. I was wrong in my previous post. This will only work with EI. The screw goes in the hole where the condenser hold down screw is on a points system. A condenser would stick up to high for the plate to fit flat.
JMOR
12-05-2013 09:45:45
 Re: round coil conversion question for Bob in reply to NOXJohn, 12-05-2013 09:33:22
Quoting Removed, click Modern View to seeSame solution that Bob used for condenser in his roll-your-own conversion would allow the Pertronix block-off plate to work with points...........just mount condenser outside of distributor as on coil mounting bracket.
TheOldHokie
12-05-2013 09:39:34
I've been thinking about doing one of those for a while - it's actually quite easy ...
TOH
JMOR
12-05-2013 08:26:14
Quoting Removed, click Modern View to seeobservant & correct, Kyle
INCase
12-04-2013 13:50:17
Thanks.
but I can not find either of those part numbers here, google or the pertronix website.
Royse
12-04-2013 16:07:59
 Re: round coil conversion question for Bob in reply to INCase, 12-04-2013 13:50:17
Try this:
Terminal is here
Cap is here
INCase
12-05-2013 06:27:40
 Re: round coil conversion question for Bob in reply to Royse, 12-04-2013 16:07:59
Thanks.
the links worked.
Not sure why i couldn't search the PNs you have me.
NOXJohn
12-05-2013 04:17:44
You need both of the above to use a remote mounted round can coil on a front mount setup. Although it says for EI it works just as well using points.
