TractorLinks.com
Show Parts for Model:
Re: round coil conversion question for Bob
Bob
12-04-2013 10:12:05
I cut them out of spare oddball distributor caps with a small holesaw.
Post back if you go ahead with the conversion... I"m interested to see how it will work out for you!
INCase
12-04-2013 11:16:17
 Re: round coil conversion question for Bob in reply to Bob, 12-04-2013 10:12:05
OK. will do,
More questions:
I presume you drilled/tapped the dist cap contact and then simply screwed the wire post & adapter plate to the dist cap?
on the alum plate over the metal distributor.. does the dist. have holes tapped or did you have to drill/tap them?
Have you seen the idea that grand valley tractors has posted on their website (click on "products" tab). Pretty neat but he's not making them yet (economy??) I don't like putting the coil there though. too close to fan and heat
thanks.
Bob
12-04-2013 16:33:54
 Re: round coil conversion question for Bob in reply to INCase, 12-04-2013 11:16:17
"I presume you drilled/tapped the dist cap contact and then simply screwed the wire post & adapter plate to the dist cap?"
Yes.
"On the alum plate over the metal distributor.. does the dist. have holes tapped or did you have to drill/tap them?"
I drilled and tapped holes.
"Have you seen the idea that grand valley tractors has posted on their website (click on "products" tab)."
Yes.
