Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 641 Firing
soundguy
11-11-2013 06:10:59
good psark for coil wire held NEAR block.. but not touching it?
if so.. then double check as old said.. rotor, clip and cap..
make sure your plug wires and plugs are ok as well.
G Archer
11-11-2013 15:50:12
 Re: 641 Firing in reply to soundguy, 11-11-2013 06:10:59
Update. Installed new Standard brand cap,rotor, and condenser.Still no fire to the plugs when cranking the starter.Loosened the dist.and rotated base where rotor lined up with # 1 terminal on dist and it will crack blue spark on tester attached to # 1 spark plug.Turn starter over and no spark.What could be killing the spark? Glenn
soundguy
11-12-2013 10:23:52
 Re: 641 Firing in reply to G Archer, 11-11-2013 15:50:12
during restore.. did you remove the distribuitor?
G Archer
11-13-2013 15:44:54
 Re: 641 Firing in reply to soundguy, 11-12-2013 10:23:52
Found the problem.Centrifigal weight support plate broke loose from the distributer shaft.Weight was striking the post in the dist grounding it out.Got to spot weld it back in place.Thanks for all the replies. Glenn
Copyright © 1997-2015 Yesterday's Tractor Co.
