8N Left Brake petal shaft almost frozen
Ronnie G
Petal frozen to begin with. Took a sledge hammer to be able to move it. Shaft must be rusted. Clutch on shaft works fine. Tried to grease zerk on lest hand side shaft. Squirted PB Blaster on inside shaft on both side. put torch on inside both ends, no help. I can manually move brake petal up & down with a lot of restriction.
SUGESSTIONS???
Spray the grease zirk part out real good with carb cleaner spray or brake cleaner spay. The let dry then pump in some ATF
