Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Getting thermostat inside the upper radiator hose....
charles east
11-09-2013 18:07:34
It is in there.... about enough to put the sensing spring into the center of the head outlet....I am going to use 2 hose clamps on the end holding the thermostat...One on the head outlet ,one the front of the thermostat This had the dirtiest oil in it I have ever seen.....(No thermostat).Now I hope for better looking plugs and less sludge....Thanks people and will let you know how this little outfit works...Charlie
Hobo,NC
11-10-2013 07:32:49
 Re: Getting thermostat inside the upper radiator hose.... in reply to charles east, 11-09-2013 18:07:34
[quote="Ken N Tx"](quoted from post at 14:04:16 11/10/13) Quoting Removed, click Modern View to see
Y'all should look for some steel cable ties are some for rack and pinion dust boots... I don't trust those plastic ones for the long haul... Before I would use plastic I would use a worm drive hose clamp custom cut to length by me...
Dielectric compound grease is the best rubber lube around... That and a pipe will push that stat home....
Tip,,, when using a worm drive hose clamp apply a drop of oil to the screw...
Ken N Tx
11-10-2013 02:04:16
Zip ties on mine.
charles east
11-10-2013 06:30:27
 Re: Getting thermostat inside the upper radiator hose.... in reply to Ken N Tx, 11-10-2013 02:04:16
My Thermostat is only 2 1/4 " into the hose right above the outlet of the head...Will it work?
soundguy
11-11-2013 05:56:02
 Re: Getting thermostat inside the upper radiator hose.... in reply to charles east, 11-10-2013 06:30:27
if you can get he hose fully on the head.. it's in far enough
charles east
11-12-2013 05:49:39
 Re: Getting thermostat inside the upper radiator hose.... in reply to soundguy, 11-11-2013 05:56:02
Thanks
