Bryce Frazier
Hey guys it's Bryce. Many of you know I recently got my hands on a Ford 2N, I was messing around with it in the shop, and discovered an interesting problem. On the right side of the tractor, there is the link that hooks to the lift arm that adjusts the angle of the implement if there was one hooked up. On the back of the housing for this adjustment there is a small bolt that sticks out, and every time I set my three point arms all the way down, it takes a little chunk it hits the axle housing, and after doing this so many times, it has clearly worn a little indent in the housing. Anyone have a solution for this? I can get a picture if you guys would like! Thanks, Bryce
