Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Oil Question
TheOldHokie
10-26-2013 16:33:01
Impossible to say from that little bit of information but it sounds odd. Around here SuperTech synthetic is about $5/qt and their conventional is about $2.75.qt. They also have a "hi-mileage" conventional that is a buck or so higher than their base line conventional oil.
TOH
L. B,
10-27-2013 09:26:36
 Re: Oil Question in reply to TheOldHokie, 10-26-2013 16:33:01
Buy the 5qt container makes $3+ a qt here.
soundguy
10-26-2013 16:46:12
that matches my observations at my local walmart..e tc.
I have 1 tractor i run on the ST 10w30 full syn.. the rest are getting C rated 15w40
L.B,
10-26-2013 18:54:34
 Re: Oil Question in reply to soundguy, 10-26-2013 16:46:12
Oil discussions are like discussions of religion and politics. Talk about oil in the Ns the manual recommended that in very cold weather it could be thinned with kerosene,talk about viscosity alteration? Long story for short Rotella T 15-40 year round but I have engine heaters, no heater I would go 5 or 10-30. old sold me on Rotella T.
ShadetreeRet
10-26-2013 22:02:50
 Re: Oil Question in reply to L.B,, 10-26-2013 18:54:34
L.B. we have to remember that when the 8Ns were built, Oils were quite a bit different than now. 30wt. which was probably the most widely used would become like molasses at below freezing temps, so it could be successfully thinned somewhat with kerosene. But then, if the bearings were a little loose in hot weather, you just added a quart or two of 50wt. to quiet them down. Ever thought about how long a modern engine would last if they were treated that way?
L.B,
10-27-2013 10:16:17
 Re: Oil Question in reply to ShadetreeRet, 10-26-2013 22:02:50
Im with you a 100%, Im just saying what would somebody say today who has never heard of that. I had. I had a long post with someone who is very up too snuff, but can only "move forward newest, yuppy sayin" I made the suggestion about 65 an 70 year tractors and made it this far with Non-det St Wt 30wt oil and is showing some crank and rod bearing wear and shows oil pressure that is not unusual as so many years have got a little low. I say these engines are very tuff, forgiving an simple. That's it and had they had proper maintenance been used with less abuse some have faced there would no parts tractors. Master of the Obvious L.B,
