TractorLinks.com
Order Ford 9N Parts Online
Re: Ford 9N hyraulic problem
J B
10-19-2013 19:06:26
I did notice that the disc was some what damaged when I took the top cover off the first time. But I never gave it any thought.
I just hope that's all it is. I took the side covers off to see if their was any leaks, but I didn't see any. I also took the top cover off to check it out didn't see anything. As soon as I get the friction disc and get it on and checked out I will let you know if it solved the problem or not. I did notice that their was no spring behind the nut that holds the lever on.
TOM N MS
10-19-2013 19:58:33
 Re: Ford 9N hyraulic problem in reply to J B, 10-19-2013 19:06:26
Thanks for the info- I also hope the disc is all your problem--look forward to hearing from you once the problem is solved..Thanks again..When we post results, we all learn..
