Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: idles but can't throttle up
10-19-2013 14:57:57
to clarify. I don't mean yank choke on full till handle pops off in your hand. I'm just talking feathering a lil choke.
still do it?
10-19-2013 16:26:29
 Re: idles but can't throttle up in reply to soundguy, 10-19-2013 14:57:57
Yes, acts as choke should up to the point that it starts to stumble (about 1/2 - 3/4) at that point the choke doesn't seem to do much. With the improvement I saw after blowing out the fuel valve, I wonder if I need to adjust the timing. I had to move the timing plate to get the top right screw out when changing points this morning. Thought I had it back in the right spot. Would it idle well and run smooth up that far if timing was out?
10-19-2013 16:35:23
 Re: idles but can't throttle up in reply to Porkman, 10-19-2013 16:26:29
and to be clear. this IS a front mount.. right?
did you actually adjust timing screw?
10-19-2013 16:32:58
didn't use a long screw and hang up the advance did ya?
10-19-2013 16:43:36
 Re: idles but can't throttle up in reply to soundguy, 10-19-2013 16:32:58
Just loosened the screw on the left outside of the housing and turned the plate to remove the screw on the top right to remove the breaker points. After replacing I adjusted back as described in FO-4 manual. Used the same screw that was already there.
