Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 9N Parts Online
Re: Ford 9N hyraulic problem
J B
10-18-2013 05:28:56
I took the 4 valves out of the pump and cleaned the cylinders out.
TOM N MS
10-18-2013 15:50:45
 Re: Ford 9N hyraulic problem in reply to J B, 10-18-2013 05:28:56
I was asking because u said it worked fine before the cleaning---I just can"t see your issue being the friction disc---not sure what it is but I just don"t think it is a friction disc thing.Anxious to know what u eventually determine the problem to be..
J B
10-19-2013 19:06:26
 Re: Ford 9N hyraulic problem in reply to TOM N MS, 10-18-2013 15:50:45
I did notice that the disc was some what damaged when I took the top cover off the first time. But I never gave it any thought.
I just hope that's all it is. I took the side covers off to see if their was any leaks, but I didn't see any. I also took the top cover off to check it out didn't see anything. As soon as I get the friction disc and get it on and checked out I will let you know if it solved the problem or not. I did notice that their was no spring behind the nut that holds the lever on.
TOM N MS
10-19-2013 19:58:33
 Re: Ford 9N hyraulic problem in reply to J B, 10-19-2013 19:06:26
Thanks for the info- I also hope the disc is all your problem--look forward to hearing from you once the problem is solved..Thanks again..When we post results, we all learn..
JMOR
10-18-2013 06:46:04
Quoting Removed, click Modern View to seeOut of the 11 valves in the pump, how did you select the 4 to clean? Just curious.
J B
10-18-2013 07:46:33
 Re: Ford 9N hyraulic problem in reply to JMOR, 10-18-2013 06:46:04
I clean the 2 on each side of the pump. I had watched a DVD on Hydraulic Repair for Ford and Ferguson Tractor and that's what it showed
