Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Live hydraulics off loader pump?
TheOldHokie
10-18-2013 04:42:14
Yes - I do it all the time using a simple flow divider. But remember that you have to balance the flow IN with an equal flow OUT. The easiest way to do that is to use the internal reservoir on the tractor for the external pump and ditch the one inside the loader.
TOH
Kirk-NJ
10-18-2013 06:25:09
 Re: Live hydraulics off loader pump? in reply to TheOldHokie, 10-18-2013 04:42:14
By putting on a flow divider would that also regulate the flow to the loader. I remember That loaders that used tractor hydraulics were painfully slow. Can I still get a quick response loader and have live hydraulics?
Thanks, Kirk
TheOldHokie
10-18-2013 08:09:21
 Re: Live hydraulics off loader pump? in reply to Kirk-NJ, 10-18-2013 06:25:09
Full pump output goes to loader valve , OUT/RTN from loader valve goes to flow divider, 2 GPM from divider goes to test port and excess goes back to sump return. The loader works just like it always did.
TOH
Patrick Wood
10-18-2013 15:27:46
 Re: Live hydraulics off loader pump? in reply to TheOldHokie, 10-18-2013 08:09:21
what is a diverter?
russb wa
10-18-2013 20:31:20
 Re: Live hydraulics off loader pump? in reply to Patrick Wood, 10-18-2013 15:27:46
More than you wanted to know about
TheOldHokie
10-18-2013 15:50:08
Flow divider - in this case a priority divider that takes the full flow in and sends a constant measured amount (3 GPM) to one circuit and the excess (if any) to a second circuit.
TOH
Kirk-NJ
10-18-2013 08:52:53
Now that sound like a plan. Best of both worlds. Thanks for the info Dan.
kirk
old
10-18-2013 08:05:56
The loader speed should pretty much stay as it is unless your using both the 3 point and the loader at the same time
Copyright © 1997-2015 Yesterday's Tractor Co.
