TractorLinks.com
Order Ford 8N Parts Online
Re: 8N hydraulic control arm issue
JCinKY
10-17-2013 18:17:06
May not need either one. The control arm could have just came out of the control valve socket; kinda like your hip bones.
Pull the right side inspection port(if sitting, by your right heel). With everything OFF stick your hand in the oil and follow the arm to the valve. The ball end should be in the socket. If the ball broke off, yep new arm or some hefting re-engineering and fabrication to reattach.
If it just popped out, you make get lucky and fiddle it back. Otherwise you will need to loosen the top cover and guide it back. Or drain oil, loosen pump and do it that way.
