Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Remove ProofMeter Needle?
whopist
10-16-2013 17:30:11
JCinKY you are the man!
I went ahead and dissembled the assembly and cleaned it. Glad I did, the shaft had some rust spots and that’s what caused the unit to malfunction on tractor.
Still afraid to attempt to remove the needle though.
[URL=http://s264.photobucket.com/user/whopist/media/ZeroSM_zps6c8f3fca.jpg.html][/URL]
JCinKY
10-17-2013 04:39:50
 Re: Remove ProofMeter Needle? in reply to whopist, 10-16-2013 17:30:11
Lookin' good. Also check to make sure the worm gear and bevel gear on the shaft line up properly and everything is free to turn. I light coat of lubricant wont hurt anything.
Man, just pop that sucker off there. It won't be that bad. If it pulled the pin and all out, there isn't really any need to remove the needle from pin.
whopist
10-17-2013 05:43:55
 Re: Remove ProofMeter Needle? in reply to JCinKY, 10-17-2013 04:39:50
Just to give an update.
I did not remove the needle, just printed new face on self stick photo paper and cut it into two pieces and applied it under the needle and screws.
OK! OK! I ran out of ink. I now have the only working 8N that “red lines” @ 2,200 RPM.
[URL=http://s264.photobucket.com/user/whopist/media/b8197729-0bf1-48b3-b302-a6bb08d6c07d_zpscdc3dcc4.jpg.html][/URL]
PDF file (Proofmeter-Faces, by Mike Taylor) is on the other forum.
Thanks to all!
whopist
Copyright © 1997-2015 Yesterday's Tractor Co.
