Anonymous-0
Well we pulled the 2n apart yesterday because it was growling when driven. I found a chiped tooth in the sherman step-up drive and some spawling on the bearings in the transmission. I have a bearing and seal kit on order. It looks like the bearings have to be pressed on and off the shafts? Is this correct and has anybody been thru this before? Also, the 2nd and 3rd gears have about a 2-3 inch span of corrosion on them when the tractor sat for a while. Will this smooth itself out? It is not terrible but it seems impossible to find new gears. Does anyone know where to find replacement gears?
