TractorLinks.com
Show Parts for Model:
Re: ford 2n transmission
TheOldHokie
10-11-2013 12:16:06
AKAIK short of having them madde you cannot get new gears for the 9N/2N transmssion. John Smith usually has a good assortment of used gearing but it's hit or miss finding the specific gears you need. Obviously the ones that fail more often are scarcer.
A press or puller is the easiest way to remove old bearings from a shaft. If the bearing is pressed up against a wide shoulder you may need a bearing separator to get behind it. You can install new bearings by heating them in an oven IF they are not sealed and/or lubricated. If they are you need a good (e.g pricey) bearing heater or a press. Overheating a radial ball bearing or applying excessively heavy loads to the outer race are both good ways to shorten it's life....
TOH
