Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Need a WAG or two!
NoNewParts
10-11-2013 06:21:15
plowing with a front blade in our area
takes a lot of weight, AND chains.
With these little Fords, no weight or filled tires and no chains,
lifting the front blade will get you stuck on wet grass :D
I didn't see what tractor you have but
about 500 pounds on the 3-point works ok with N-NAA, etc.
like said, use check chains once you lift it up.
bigger?, my loader 5000 has a 600lb counterweight with 390lbs
of iron MF weights stacked on top
my front plowing NAA has filled tires, a 500lb counterweight (or heavy rear blade) and multiple sets of chains.
works ok, but in the right conditions, -icy snow or heavy snow on hardpack snow-ice-....forget it
have to get out the 4 wheel drive tractor
