I'm trying to fix a lower lift arm loose pin problem on my 1951 8N. Trumpet casting came right off without a hitch.
Now to remove the pumpkin gear, it's just resting on the axel shaft and drive shaft gear right? It will just pull Straight out?
I'm thinking of putting a rope through it to hold it up. Should I mark something so I get the gear teeth matched up on re-assembly?
Do those cotter pins look factory? Or, has someone been in there before me? It just seems to me the factory would have done a neater job!
Joe
Joe
