John Schmincke
Just had a 12 x 28 AG tire & new tube put on a new rim from this site. Previous rim rotted away from Calcium leak through the old tube. Elected to not put fluids in as I also just got a set of chains. Discovered the tire has a 2-3 cuts between the treads from running over something sharp I guess so my question is what would be a suitable pressure to keep the rears at to prolong the life of the tire? When I saw the cuts, I checked the pressure the tire place put in - is 28lbs. Tire says no more that 45. Its a 4 ply nylon.
Thanks in advance - John
