pto override
steve 43
How does that orc that is sold here fasten to my pto stub...same as my 1-1/8 to 1-3/8 adapter with a pin? I couldnt tell from picture...
Some use a button-type catch but they won't fit on most old Fords. The rest mostly have a hole through the ORC with a grease fitting on each end. RYou remove the grease fittings and drive in or out to install or remove. Rube goldberg, yes, but hard to say how else it could be done without making the ORC much longer. Some come packaged with a D-type pin/retainer which seems to be intended as a shortcut alternative to the roll pin, but my experience is they don't work very well, to say nothing of making it difficult to keep greased - and ORCs must be greased frequently.
(quoted from post at 15:07:48 10/10/13) How does that orc that is sold here fasten to my pto stub...same as my 1-1/8 to 1-3/8 adapter with a pin? I couldnt tell from picture...
Do you happen to know which style this site sells? I am I rite to assume that the push on style requires a groove in the pto stub on the tractor?
The pictured one on this site appears to be a black version of the gold roll-pin style one, which would fit your PTO.
Where it is made and whether it is better or worse than the gold India ones is harder to say.
(quoted from post at 22:07:15 10/10/13) Do you happen to know which style this site sells? I am I rite to assume that the push on style requires a groove in the pto stub on the tractor?
