TractorLinks.com
Show Parts for Model:
Re: Starter ?
Dell (WA)
10-05-2013 14:56:20
gblj........you do know yer 3-terminal starter mounted solenoid is activated by GROUNDING the little middle terminal by the BIG thumb button up by yer tranny shifter lever. It is not uncommon fer yer BIG clod hoppers to accidentally kick the starter activation wire as you climb into the saddle and SHORTING the wire to ground as it goes the the hole in the bottom of the steering column sheet metal. Me? I'd replace the starter activation wire with #14ga stranded insulated copper wire with correct terminals on both ends. (actually, 16ga or 18ga is good enuff, but I like the mechanical strength of 14ga) Simple, eh? .........electrical Dell
