Front wheel weight? (pic)
Royse
Is that a wheel weight inside the right front wheel?
Not like the ones I've seen.
Haven't seen that one either.
Looks like it might be a brake drum. Same bolt pattern behind the wheel, add a few lbs anyway. Just a guess.
It sure looks like a brake drum to me. Supposedly the front hubs off of a mid-30's Ford car will fit right on a N spindle. The bolt pattern for the wheels looks almost exactly like a 9N/2N bolt pattern but they are NOT the same. Back in the old days using the Ford car hubs and wheels was the cheap and easy way to get wider tires for FEL use.
Imagine how much weight those hollow drums will weight with concrete. At the seeds of the "N", I really don not tink outta ballance will matter.
John,PA
They're off a 1936 ford deluxe. The hubs and rims go together. The rims will not fit the standard 9n/2n hub, Although they look alike, without some alteration becuse the holes won't line up. They were a good alternative for a 9n/2n with a loader. In anyone is interested in a pair of hub with 4 tire/rims my email is open. Cleaning out will sell cheap.
Kirk
Here's a photo of what this look like. They would look kool on an N if you could find the center hub caps for them.
kirk
