Noisy 8n PTO, how hard and expensive to repair
hzl6cm
I have an 8n with a noisy PTO, in ballpark terms, how hard is that to repair and how expensive? Otherwise the tractor is in great shape. Thanks!
(quoted from post at 08:31:35 10/05/13) I have an 8n with a noisy PTO, in ballpark terms, how hard is that to repair and how expensive? Otherwise the tractor is in great shape. Thanks!
Cam blocks - 2@$40 ea.
Bushing - 1@20. ea.
Sundry gaskets and seals while you are in there.
Half a day R&R the PTO if you are quick.
Depends on what's causing the noise.
If it's the PTO bearing, that's cheap & easy. Pull the shaft out & replace it & the bearing. Or if it's really the ORC, replace that.
You need to pin point the source of the noise.
Bad ORC?
PTO engaged?
Noise increase w/ shaft RPM's?
Does the PTO disengage while in use?
Remove the inspection plates & see if you can better pin point the source?
75 Tips
Just to add what they said...is it making a thumping noise when you are using it? Or a big vibration you can feel through the floorboard?
