TractorLinks.com
Order Ford 9N Parts Online
Re: What is norrmal on th 9N/2N
Royse
10-04-2013 18:17:27
Check out John Smith's site for lots of information on the aux transmissions. John's Site
John Ayres
10-08-2013 06:14:31
 Re: What is norrmal on th 9N/2N in reply to Royse, 10-04-2013 18:17:27
There is nothing I can find on the lever for the left side there.
Royse
10-08-2013 16:31:37
 Re: What is norrmal on th 9N/2N in reply to John Ayres, 10-08-2013 06:14:31
Left side is the very first picture on the page.
Sherman step-up, same handle as your picture.
Can't really rule out 9N from the oval radius rods, they can be swapped.
Not much difference in 9N/2N, you can check the serial number,
but engines can be swapped too.
Date codes on the castings will tell you if you really want to know for sure.
Tiger Joe
10-08-2013 06:24:43
looks like a sherman lever to me. check out this site for a few pics:
http://www.oldfordtractors.com/sherman.htm
John Ayres
10-08-2013 05:46:28
Here are three pictures of what I have . The serial number will require work as I can't see anything without steel wool. The lever on the right appears to be a Howard trans as it does have a rototiller attached to it. Anyone know what the lever on the left for the PTO is as it is pre tranny? I know it has two speeds for the PTO with nuetral in the middle however not clear what it might be from Smihts site. Also this tractor is painted red with 9/2N rear wheels/pedals however from the oval beams can we rule out 9N?
