3 point implement pin things
pierce
whats the proper name for the two pins on a 3-point implement that go into the lower arms? and what size do our 8N's use? I've got 1 implement that doesn't have any pins and rather than moving them back and forth, I'd as soon get a pair of new ones.
I have heard them called different things, linchpin is one name. There should be a loop in the end of the lift arms that holster the pins and each pin is attached to the arms with a small link chain so they stay with tractor and are at hand for each implement.
If you need the pins that are bolted to the implement,make sure you take an old one with you the thread size can varie,depending on what size hole you have in the implement,if you need the linch pins I think they are 7/16 dia and about a buck a piece.
(quoted from post at 18:25:35 10/04/13) whats the proper name for the two pins on a 3-point implement that go into the lower arms? and what size do our 8N's use? I've got 1 implement that doesn't have any pins and rather than moving them back and forth, I'd as soon get a pair of new ones.
Go to Tractor Supply dot com and search for "CountyLine® Draw Pin, Cat 1, S070208TSC".
You can Google it too. Google takes you straight to that part number.
TSC gives you other options to look at.
Go to tractorsupply . com and search for "draw pin" (which is what it sounds like you are looking for) and "lynch pins". They have several different sizes of each. For the draw pins, you will want them a little longer if you are using anti-sway bars.
linchpin is what they are commonly called around here. There are several different styles. If you have a farm supply store or a decent hardware store, they should be stocked.
Colin, MN
I thought the lynch pins were the things you put in the ends of the lift pins to secure the arms to the implement ?
(quoted from post at 07:26:12 10/06/13) I thought the lynch pins were the things you put in the ends of the lift pins to secure the arms to the implement ?
They are. Tractor Supply sells a wide variety of lift pins,lynch pins, hair pins, etc.
