Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Moving a Little Grain
Royse
10-03-2013 20:58:04
8N still looks good Colin!
Don't let that wagon push you down a hill!
We use a similar gravity box to store feed for calves.
We have a little wooden box with a tin floor we set under the door.
Set two 5 gallon buckets in the little box and open the door to fill them.
Then carry the buckets in to feed and empty the box in the feeder too.
Colin King
10-05-2013 18:43:51
 Re: Moving a Little Grain in reply to Royse, 10-03-2013 20:58:04
Thanks, Royse! For not being shedded, I'm pretty please with the Van Sickle paint. It's fading but has held up pretty well.
No hills to worry about, thankfully. If you look closely, you can see a wooden box below the gravity box shoot. It's big enough to hold a bucket and about 150lbs of feed. I use a grain shovel to fill my buckets and then off to the chickens.
Colin
john B. ne in
10-08-2013 13:21:56
 Re: Moving a Little Grain in reply to Colin King, 10-05-2013 18:43:51
A little trick I use is clear enamel if the paint is still good but faded from being out in the sun to long. It's really amazing how much better a tractor will look if it has a little shine! A couple of spray cans will spruce up a tractor quite well.
Fred Werring
10-06-2013 07:59:29
Something that works for me
Took a couple pieces of 1X6 or 1X8, I forget which, angled the end cuts to match the angle of the chute to the bed, bolted them to a couple pieces of angle iron and bolted that to the chute, tapering it down from the door to 6" or so opening at the end of the chute...a feed funnel. Hopefully your chute is tall enough a 5 gal bucket will fit underneath.
While I still put my buckets in a washtub while filling, I don't have to clean up near as much feed.
Course you gotta unbolt them if you need to raise the chute.
Fred
