Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: What could have happened? H12 Plug issue-Dell?
36 coupe
10-01-2013 03:01:02
Ill repeat.Measure the reach of the old and new plugs.The shorter reach plugs may have been put in the engine for a good reason.J series Champions have a shorter reach.Its a simple matter to compare the reach of the plugs that were in the engine to the H12s.No need for ideas that the plugs are hitting the piston or block.Those who say this dont know that it cant happen in this engine.There was an aluminum High compression head sold for this engine that could be different as to spark plug location.
greywolf224
10-01-2013 09:36:51
 Re: What could have happened? H12 Plug issue-Dell? in reply to 36 coupe, 10-01-2013 03:01:02
I worked on a few Pontiac and Chevy engines in the past. Remove all of plugs and place a short wooden dowel straight down in one of the spark plug holes. Slowly spin the engine by hand where the valve should move the dowel up and down and measure the max and min heights of the dowel. The max height measurement is just beyond the max reach that the spark plug can be without hitting.
Keep in mind your max reach can be different then specs due to:
Milled heads
Thin gaskets
Custom domed valves
Loose valve train.
There is a spark plug adapter called anti fouling something or other that screws into the head and the plug screws into it. It will buy you some reach.
Copyright © 1997-2015 Yesterday's Tractor Co.
