Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 9N Parts Online
Re: 9n resistor block
09-28-2013 19:24:37
Your first two readings are normal, and the third might be.
If the points are closed, you would not get battery voltage there.
Only about half of battery voltage. (roughly)
Try connecting it there while rolling the engine over.
It should flash at you as the points open and close.
If not, does it light if you disconnect the wire on that side?
I suspect it will, in which case the resistor is probably good
and the points are not opening and closing properly or something
else is grounding the circuit in the distributor, such as the
condenser wire or the little insulator where it connects.
Let us know what you find.
