TractorLinks.com
Order Ford 9N Parts Online
Re: 9n resistor block
soundguy
09-28-2013 19:23:32
you may be doing your test wrong.
remove the 'coil' wire fromt he resistor terminal before testing for power there.. and testing continuity.
power at the lower terminal is normal.. power at the terminal hooked to key, when on is normal. other terminal should have it too. points state will make difference in actual voltage readings if using a meter vs a lamp.
post back
