TractorLinks.com
Show Parts for Model:
Re: steering sector
soundguy
09-17-2013 06:24:01
i agree.. most likely a thrst bearing issue.
don't wimp out.. pullthe box down. thay are not too hard to fix.
the early boxes are lessadjustable than the late ones.. but still rebuildable..
cdv
09-17-2013 14:30:44
 Re: steering sector in reply to soundguy, 09-17-2013 06:24:01
I was thinking sector because when I jack it of the ground it steered so nice and smooth
soundguy
09-17-2013 15:03:27
 Re: steering sector in reply to cdv, 09-17-2013 14:30:44
and yet.. a thrust bearing would do that too. and so would a worn spindle bushing.
your diagnostic tests are incomplete to draw a comclusion.
does the steering wheel , when turned lock to lock, rise from or fall into the column?
Cdv
09-17-2013 16:29:58
 Re: steering sector in reply to soundguy, 09-17-2013 15:03:27
Sounds guy you maybe rite is dose locked up I tryed to grab the tire and turn it but turns nice with steering wheel
carlntexas
09-17-2013 07:10:44
Soundguy is right not that hard to do get an FO-4 manual and lots of grease rags it's messy. I used a pressure washer to blow most of the grease out.
soundguy
09-17-2013 09:04:01
 Re: steering sector in reply to carlntexas, 09-17-2013 07:10:44
I've never torn one apart and ONLY found a bad sector gear.
They have almost always needed someting else.. and MOST of the time.. it was NOT a sector at all.. :)
