TractorLinks.com
Show Parts for Model:
Re: Charge rate
JMOR
09-16-2013 06:16:04
Quoting Removed, click Modern View to seeInstall this jumper from field to ground & this will force the generator to output its maximum possible current. Then look at ammeter & at voltage battery post to battery post after five minutes & compare to same voltage measurement taken before starting.
[URL=http://s192.photobucket.com/user/JMOR_photo/media/Charging/gen_8N_full_field_jumper.jpg.html][/URL]
Ken B 8N NC
09-16-2013 10:28:01
 Re: Charge rate in reply to JMOR, 09-16-2013 06:16:04
I jumpered the 2 points that you indicated on both generators and the amp meter went full scale to 30 amps. It still seams to me that the VReg is bad, no regulation.
JMOR
09-16-2013 11:51:55
 Re: Charge rate in reply to Ken B 8N NC, 09-16-2013 10:28:01
Quoting Removed, click Modern View to seeI would concur, with the exception, that if battery is already fully charged or has internal problem that would command the VR to cut back on charge current. Might be nice to try another battery or make sure that one is well discharged & re-look using VR.
pierce
09-16-2013 11:58:37
 Re: Charge rate in reply to JMOR, 09-16-2013 11:51:55
said 'command' is the voltage of the battery. if the battery is at about 6.3 or 6.4V at room temperature, then its fully charged, the charge current would drop to very little.
