Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Help with specs on a Vickers Vane Pump
TheOldHokie
09-15-2013 10:09:19
You are going to need considerably more than the fittings. You will need a flow divider for the test port supply and I would also suggest you put a check valve on the test port line to prevent reverse flows. If you try to force feed the 3pt at 14 GPM the lift will go to the top very quickly and you won't be able to get it back down. The maximum you can feed it is about 2+ GPM. And any oil you send to the test port has to be taken from the internal pump's sump. If you send in oil from an external loader reservoir will simply pump the loader dry and fill the rear end to the top. Call me and we can discuss what you have in mind. It's not hard to do but you have to balance the flows.
TOH
greywolf224
09-15-2013 17:24:06
 Re: Help with specs on a Vickers Vane Pump in reply to TheOldHokie, 09-15-2013 10:09:19
TOH I drew up some plans that I want you to look over so you have an idea of what I am trying to do before we talk. Can I get them to you some how. It's a Microsoft Word document.
TheOldHokie
09-15-2013 18:04:00
 Re: Help with specs on a Vickers Vane Pump in reply to greywolf224, 09-15-2013 17:24:06
Simply send email with the file as an attachment.
TOH
greywolf224
09-15-2013 18:43:17
 Re: Help with specs on a Vickers Vane Pump in reply to TheOldHokie, 09-15-2013 18:04:00
Just sent to your 'oldhokie@verizon.net' acct.
