TractorLinks.com
Order Ford 8N Parts Online
Re: 8n hydralic remote
soundguy
09-14-2013 16:05:21
techincally yes.. but there's more to it than a simple yes..
1, you can chaint he 3pt down, engage the pto and tap the pressure test port with an orb fitting, runt hat line to a OC ( logsplitter? ) DA valve, with it's return line dumping into the trans sump. then use da functions on it's ports. PTO provides hyd flow and pressure ( 1500-1700 psi up to 2.85 gpm ).. but is not live... so if foot is on the clutch, or pto not spinning.. it dies.
now.. a couple members here make add on engine pumps that guve you either more 3pt flow, or live 3pt with no pto involvement.. or the option of a remote ( and/or really )
TOH and Zane are the people that make these kits..
still there are other engine mounte dpump options you could fab, depending on if you had a loader or not..e tc.
kylemorley
09-15-2013 08:53:46
 Re: 8n hydralic remote in reply to soundguy, 09-14-2013 16:05:21
And lets not forget that Kevin LaRue has some very good instructions for a DIY version on the "other site".
Look for HOW TO PROVIDE LIVE HYDRAULICS FOR ALL FORD N-TRACTORS
soundguy
09-16-2013 06:48:25
 Re: 8n hydralic remote in reply to kylemorley, 09-15-2013 08:53:46
Havn't seen that one.
I gave up on the other site mostly as it's not easy to post.. I tire of having to enter captcha number sequences 4-5 times a pop to get a post to go thru.. and then when it goes thru.. 90% of the time getting a site error because the shared server is busy.
I can't afford to spend 10+ minutes trying to post a single message.. just not worth it...
David Owen
09-14-2013 17:07:16
Thank you
