Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Help with specs on a Vickers Vane Pump
greywolf224
09-14-2013 15:53:37
After putting pen to paper to draw up a diagram, I realized that I was overlooking the fact that I don't want to plumb up to the internal hydraulic oil via the drain plugs, rather I wanted an external mounted tank to supply the remote hydraulics. In doing so I could not also have a live PTO utilizing the TEST port. I wouldn't be keeping the systems isolated.
So is anyone using the internal 5 gallons of hydraulic fluid to supply a 14gpm pump that connects to the TEST port and some remote hydraulic connections?
Just wondering if there is enough fluid to supply everything and still keep the transmission, differential and internal hydraulic system supplied.
TheOldHokie
09-14-2013 17:23:28
 Re: Help with specs on a Vickers Vane Pump in reply to greywolf224, 09-14-2013 15:53:37
greywolf224 said: (quoted from post at 18:53:37 09/14/13) After putting pen to paper to draw up a diagram, I realized that I was overlooking the fact that I don't want to plumb up to the internal hydraulic oil via the drain plugs, rather I wanted an external mounted tank to supply the remote hydraulics. In doing so I could not also have a live PTO utilizing the TEST port. I wouldn't be keeping the systems isolated.
Yes. You are pushing the "thermal envelope" with 14 GPM but a lot depends on the duty cycle of the hydraulic loads. A FEL can easily run 3:1 on reservoir capacity and that is exactly how Ford/Dearborn designed their loaders. I believe the internal reservoir on your 19-70 loader is very close to 5 gallons so you could switch to the internal sump (or connect the two) and have the best of both worlds with little or no worry. The only concern is heat dissipation and either way you don't have a problem with your current loads. The 3pt is ZERO additional load and a live hydraulics hookup to your existing loader pump is butt easy - just takes a few $$$ for the plumbing....
TOH
This post was edited by TheOldHokie at 17:30:49 09/14/13.
greywolf224
09-15-2013 08:40:06
 Re: Help with specs on a Vickers Vane Pump in reply to TheOldHokie, 09-14-2013 17:23:28
TOH interested in a few of ur hydraulic fittings. Specifically the test port fitting so that i can attach a 3/8" pressure hose for live pro and the trany cover filler fitting so that i plumb a return. Thinking that to save some shipping you can send them back along with the pump bracket.
TheOldHokie
09-15-2013 10:09:19
 Re: Help with specs on a Vickers Vane Pump in reply to greywolf224, 09-15-2013 08:40:06
You are going to need considerably more than the fittings. You will need a flow divider for the test port supply and I would also suggest you put a check valve on the test port line to prevent reverse flows. If you try to force feed the 3pt at 14 GPM the lift will go to the top very quickly and you won't be able to get it back down. The maximum you can feed it is about 2+ GPM. And any oil you send to the test port has to be taken from the internal pump's sump. If you send in oil from an external loader reservoir will simply pump the loader dry and fill the rear end to the top. Call me and we can discuss what you have in mind. It's not hard to do but you have to balance the flows.
TOH
greywolf224
09-15-2013 17:24:06
 Re: Help with specs on a Vickers Vane Pump in reply to TheOldHokie, 09-15-2013 10:09:19
TOH I drew up some plans that I want you to look over so you have an idea of what I am trying to do before we talk. Can I get them to you some how. It's a Microsoft Word document.
TheOldHokie
09-15-2013 18:04:00
 Re: Help with specs on a Vickers Vane Pump in reply to greywolf224, 09-15-2013 17:24:06
Simply send email with the file as an attachment.
TOH
greywolf224
09-15-2013 18:43:17
 Re: Help with specs on a Vickers Vane Pump in reply to TheOldHokie, 09-15-2013 18:04:00
Just sent to your 'oldhokie@verizon.net' acct.
