Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: I picked up a meter
soundguy
09-14-2013 14:51:59
do you indeed have a side dizzy tractor? 5 nipple cap?
Jim in Eastern NC
09-14-2013 16:29:17
 Re: I picked up a meter in reply to soundguy, 09-14-2013 14:51:59
And your voltage readings only represent half of the necessary electrical equation. Amps sufficient to do the job may not be passing through the wires and connections and ignition switch. Voltage is kind of like water pressure, you might have 60 psi in a 1/2 inch water hose, but you can't fight a fire. Amps do the work, think of a fire hose with 60 psi, you can do a lot more. You simply have one or more bad connections, and don't overlook crimped terminals for the culprit..., they can crimp down on one strand of wire and still carry volts, but few amps; and crimped connections corrode invisibly under the plastic sometimes. Fix what's wrong.
Copyright © 1997-2015 Yesterday's Tractor Co.
