TractorLinks.com
Show Parts for Model:
Re: I picked up a meter
finishsuper
09-14-2013 04:57:27
If I understand the description of your wiring, you're losing almost .8V through the key switch. This isn't good. You should read battery voltage at the battery, at the key switch, at the "input" side of the ballistic resistor, on the "output" side of the ballistic resistor (with points open), and then at your coil (again with points open).
Check for a loose connection anywhere you are losing voltage. Tight and bright. Doesn't take much to sap your voltage to where you don't have enough for good firing. (Same problem as I had on my Dad's 2N).
Best.
