Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Jubilee swinging drawbar
old
09-13-2013 18:17:40
Why use the 3 point draw bar at the same time as the good swinging draw bar made to bolt under the rear end and then you have a part that bolts on under the PTO for the other end of the bar?? I prefer my loads up close to the rear end so that you do not have front end poop up problems from having the load out 2 plus foot behind you
HCooke
09-14-2013 05:09:35
 Re: Jubilee swinging drawbar in reply to old, 09-13-2013 18:17:40
I actually like a trailer hitch to be a little further back so that the trailer tongue does not hit the wheels when making sharp turns. I use the 11 hole draw bar to pull small trailers and boats around my place.
old
09-14-2013 08:10:19
 Re: Jubilee swinging drawbar in reply to HCooke, 09-14-2013 05:09:35
Most trailers I have seen sit back far enough that is not a problem unless of course you turn to shape which can cause problems with any tow vehicle
Chuck NH
09-14-2013 14:23:33
 Re: Jubilee swinging drawbar in reply to old, 09-14-2013 08:10:19
I would like one for moving my trailer in my yard, pulling a hay wagon, and because it was a Ford option for my tractor. I do understand that with a heavy tongue load it can make the front of the tractor light, so with a little common sense, we should be alright if I'm able to find one. Thank's for your concern!
Copyright © 1997-2015 Yesterday's Tractor Co.
