Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Looking For?
Ultradog MN
09-13-2013 17:03:21
If you have an N that has sentimental value and you want to run a rototiller then by all means keep looking for a Howard.
Spend a Thousand or Two to buy it plus whatever repairs it needs.
If you aren't attached to your tractor for sentimental reasons then sell your N and look for a 3000.
Find the right one and you will get an 8 speed tranny capable of running a rototiller. You're also likely get live pto, live hydraulics, differential lock, power steering, 12V standard, much greater longevity from a gas or diesel engine, remote hydraulic valves, a host of other refinements. You'll have that same sweet, nimble workhorse that is a Ford and it will run all of your existing implements.
You'll be money and tractor ahead.
09-13-2013 19:08:13
 Re: Looking For? in reply to Ultradog MN, 09-13-2013 17:03:21
That sounds doable and makes me think. I know everyone says ya cant till with a N but I have for 20 plus yrs I guess I didn't know it cant be done. Once its broke up its easy. I done gardens,yards and horse arenas. What I want was for bush hoggin.
09-13-2013 19:59:00
 Re: Looking For? in reply to L.B,, 09-13-2013 19:08:13
If you have been tillin with an 8N, I believe that you could brush hog it just as well. I hope you have ORC.
09-14-2013 00:49:39
 Re: Looking For? in reply to Kornfused, 09-13-2013 19:59:00
Yea on ORC, I think the use of a bush hog is not uniform from one person to the next on the site. In S Missouri it is used to tackle oak and cedar trees before they take over a pasture. Some places they can be used on cat tails, and some use it on grass. I use mine on kochia weed, sun flowers with stocks bigger then broom sticks,sweet clover,wild alfalfa you name it. Even in low it will bog ya down and ya have to go over it more then once and different angles. A bush hog does not cut as much it uses the blades to hit hard and rip stuff into, it does not always cut clean like a rotary or finish mower.In my case if I had to rely on a clean cut a bush hog would be useless as a finish mower. L.B, Master of the obvious
09-14-2013 14:22:17
 Re: Looking For? in reply to L.B,, 09-14-2013 00:49:39
understand agree with what you are saying - I'm just saying that if you have been rototillin with it all along, then you ain't new to this rodeo and I believe you could handle it without the Howard.
