Paul Daniel
New User
I had asked before some questions about my ford nat starting and got alot of responces and I really apperciate all who sent responces. Here is where I'm at on it. I took all the plugs out put oil directly into the cylinders then ran a jumper from battery to + side of coil Tractor fires right up it even runs after you remove the jumper. I let it run for about 15 minutes I cut it off and it wont start back even with the jumper wire. I ordered a tune up kit with wires,cap,button,points and condensor. I have even tried bypasses the ignition switch and that did no work. I know I'm doing the shootgun approach by throwing parts at it, but the tractors been down for about a month and I am getting ------!!!!!
6 volt positive ground side mount distributor
ANY SUGGESTIONS THANKS!!!!!! Paul
