Question on back blade repair
wsmm
The left pin of my back blade where the lift arms attach has come loose. My blade has a large tube that the pins go into and appear to be attached somehow inside the tube. I have to hold it while putting the list arm and stabilizer bar on to keep it from falling inside the tube. I don't want to cut off the end to reattach the pin from the inside as I'm not that great of a fabricator or welder to get every thing back together the way it should be. I wondering if I could weld a small bead around the outside, welding the pin to the plow tube.
Thanks
Bill
i have many implements where the pins are simple welded on, vs bolted thru.
your implement.
surely is the EASIEST fix.
can always cut out the weld if you want to do it right later on.. not a biggie with a torch or a grinder.. etc...
Seen many piece of equipment like that and yes also seen many of the pins welded in place due to a problem like you are having so yep weld it on place and be done with it till you maybe break it off
