Matt Yellen
New User
The issue I am having is with lifting my 3 point hydraulics. When I move my control lever to the up position with the PTO engaged my 3 point arms move up very slowly, if they have no load on them. They will not reach their max travel.
If I have a load on them, they will not move at all.
Today I was playing with the draft control lever and I found that if I slowly move it to the down (forward) position, the 3 point arms will lift all the way up, even with my load. If I go to far forward with the draft control lever, the arms fall back down.
I can control the height with a mix of the draft lever and the hydraulic control lever. The draft lever will not stay in any position other than up or down (forward), which means my 3 point hydraulics aren't working for me. What is wrong and what do I need to do to fix it.
Thanks
Thanks
