TractorLinks.com
Show Parts for Model:
Re: Gonna install my sherman combo...finally
DollarBill
09-04-2013 01:03:01
I'd have a couple of each thickness - Hard to say in advance how much wear your particular transmission has seen.
Paper shims not required between metal shims.
To get the correct alignment for the shifter hole. Install the transmission and measure from the inside - Use a 1/4" bit to start. I was amazed at how easily the hole saw went through the cast iron. Make final adjustments with a rat tail file. The rubber grommet will cover minor transgressions.
greywolf224
09-04-2013 19:02:02
 Re: Gonna install my sherman combo...finally in reply to DollarBill, 09-04-2013 01:03:01
Thanks for the info. So where exactly does the paper gasket 9N7086 go???
greywolf224
09-04-2013 19:01:01
