Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 8N Parts Online
Re: leveling gear box on 8n froze up
ZANE
09-03-2013 19:25:44
First thing you have to do is take the crank handle out of the gear box. There is a pin through the crank retainer that has to come out first then the whole shaft should pull out leaving the crank gear in the houshing. Then just drop the threaded rod part on a piece of hard wood and the whole thing will pop out the top and the bearing will be at the bottom of the housing. It probably will be bad.
Zane
LDoyle
09-04-2013 10:33:41
 Re: leveling gear box on 8n froze up in reply to ZANE, 09-03-2013 19:25:44
Thanks Zane . Now if and when I get the rod out , how would you get to the bearing to knock it out ? It s possible I could see how once I reach that point but just in case it s not obvious I thought I would ask .
ZANE
09-04-2013 13:13:44
 Re: leveling gear box on 8n froze up in reply to LDoyle, 09-04-2013 10:33:41
The bearing is a simple thrust type bearing. It's just sitting there under the bottom gear attached to nothing.
Zane
LDoyle
09-04-2013 20:45:52
 Re: leveling gear box on 8n froze up in reply to ZANE, 09-04-2013 13:13:44
Thanks everyone , it s all apart now and I m cleaning it up . Even the bearing turns and is not froze up so I guess I got lucky . Thanks again for all the help .
